Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: 1968 rear Caliper ID. Help appreciated
    Hi all. I am in the process of going through the brakes on a 1968 911 that has been sitting for almost 25 years. I took the rear calipers off, and ordered a rebuilt set through PMB. The rears I got are not matching the ones I took off and I am trying to figure out why. Here are pics of the tears I took off, then I’ll post the tears I have to put on. Thanks. Name:  5D85CADF-90B5-434D-B91B-8AD0F536DDCE.jpg
Size:  77.6 KBName:  8CE8B881-4F3E-42E3-B8E9-11D5335A99A0.jpg
Size:  71.4 KBName:  832C5BED-D5C5-4E76-B1FA-6178A4EFA1B5.jpg
Size:  64.6 KBName:  702132B2-2680-4BDF-821D-C2C54A6E485F.jpg
Size:  65.1 KBName:  B093557F-E751-4375-8B46-FFDBA3AAA4A1.jpg
Size:  138.1 KBName:  7EFA9BEA-D6E8-4FAF-B5B8-353A8F7C115F.jpg
Size:  133.3 KBName:  AE9886A0-F426-4B2B-8E4E-DC2BA9280CC6.jpg
Size:  129.3 KBName:  0796F38A-58D5-4B82-AD9B-AD8C1482B991.jpg
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    it looks like the caliper you removed is for vented rotors, and the one you received from rebuilder is for non-vented rotor.
    registry #2072
    Yes, I have just compared the rotor I took off to the new rotor I put on, and the old rotor is vented. What came stock on a US spec 911 for 1968? VIN 11830XX
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    You may want to contact PMB. I have just sent my 68 calipers and Eric at PMB has been very helpful. He also has a lot of info on the 67-68 rears on PMB website.
    Scott
    http://www.pmbperformance.com/articl...173/189347.htm
    1968 911S
    1986 Carrera
    2006 Carrera S
    Aug 2010
    Colorado
    If those are off a 67S or a 68L or S fitted for vented rotors I think they have 38mm pistons upgraded from the non L or S 35mm pistons. If so those are hard to come buy and valuable. The S vented rotors are expensive. I have 944 rotors milled down 2 mm on my car.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Aug 2012
    Florida
    Yes, exactly. Eric @ PMB was helpful with identification. One telltale according to him is the existence of 11mm nuts on the insides of the caliper. Also, he asked that I remove the boot, and send a picture of the piston as well, so that he could confirm the larger 38mm.
    NOBODY had rebuilt readily available, so I sent mine off to Utah, and am excited to see the new jewelry for my car.
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
    Man, it’s so great to have such a knowledgeable community to draw info from. Thanks.
    Yes, these look like the Wide L calipers, except they don’t have crossover tubes. The nut size is indeed 11mm. Any ideas what/why that might be?
    The 'S', 'L' and sporto cars came with the vented rotors.
    Mine is not an L or an S.
    Aug 2009
    SF Bay Area
    The calipers are not 68 calipers but 69 calipers. Your car appears to be a 69 year model car not a 68. Big difference in the brakes and calipers from a "68" will not fit on a "69". Yes, you got "non vented" rotor calipers which were common on 911Ts and 912s.
    Jim
    Eric's buddy
    PS: 68 Calipers are very different than yours.
