Page 16 of 29 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 289
Thread: Ambition Fulfilled - my 1972 911T coupe
  1. #151
    Aug 2011
    Eugene, OR
    Quote Originally Posted by Longballa View Post
    Do it now and paint with the hinges on so the bolts and hinges are painted on the car like the factory did it. Easy to fix now.
    Yeah, we will work on this. But in the end, if unpainted bolt heads is the biggest issue I end up with on a driver-quality car, I can live with it.
    - Arne
  2. #152
    Jul 2006
    Corvallis, OR
    If you go that way just paint the bolts separately. Screw them into a cardboard box and paint them washers and all. Then install them with a plastic bag over the bit to help not chip paint when torqueing them down.
    72S, 72T now ST
  3. #153
    Actually the bolts are the least problem, it's not chipping paint on door and fender edges, really best to do aligning before paint. Your call.
  4. #154
    Yes, I also agree, do the aligning before paint, trust you'll be glad you did, even if it's only going to be a driver
  5. #155
    Aug 2011
    Eugene, OR
    Quote Originally Posted by savagejayj View Post
    Oh yes, the plan has always been to have the doors re-hung and aligned before paint, as the painter wants the parts painted together in their normal positions so that the metallic grain is consistent over the whole car. I've seen too many cars where the doors look ever so slightly different because they were not painted in place.
    Of course, the drivers' door will have to come back off briefly after paint so that the antenna can be installed...
    - Arne
  6. #156
    Aug 2017
    el sobrante ca.
    you probably know.... but just in case..... once doors aligned, remove only the hinge pin to remove the door. this way you don't have to fiddle with resetting the hinges
  7. #157
    Aug 2011
    Eugene, OR
    That was my recommendation to the painter, but since I'm not doing the work, how he does it is up to him. He guarantees that it will have correct door fit and be beautiful when he is finished.
    - Arne
  8. #158
    Aug 2011
    Eugene, OR
    Apparently the painter knows what he is doing. The doors are back on, and the gaps and fit are great. Getting ever closer...
    - Arne
  9. #159
    Aug 2011
    Eugene, OR
    Progress is slow on the car itself over the holidays, but I've continued to work on cleaning and prepping parts for reassembly. I've got stuff scattered all through the house...
    - Arne
  10. #160
    But this is the fun part, just like Xmas morning every time you open another box
