Results 1 to 7 of 7
Thread: Suspension pan R/R - seeking SF Bay Area body shop recs & process advice
    Member dogLeg's Avatar
    Aug 2015
    SF Bay Area
    I am looking for recs for a SF Bay Area body shop to replace the suspension pan on a 70.
    Recs and other advice appreciated. Thanks much! Tim.
    Tim
    1970 911T
    #3257
    Jerry Woods Ent. In Campbell Ca.
    Aug 2009
    SF Bay Area
    Steve at Classic Autobody in Berkeley. He done a bunch of them.
    Aug 2015
    SF Bay Area
    Thanks! I rang both yesterday to discuss.
    Aug 2015
    SF Bay Area
    Appreciated the two recommendations above however they were not able to take this on so I hired Jennings Kustom Restorations in Concord CA. The job ended up being worse than anticipated rust wise, we found two holes and some very thin areas. The front of control arm (pictured above) was also a significant safety concern. Took about 2 weeks, texture match is good and the car is driving straight, no issues. I ordered the pan from www.restoration-design.com, it arrived in about 5 business days.
    Tim
    1970 911T
    #3257
    Jan 2017
    NY/VT
    That was a lot of rust, looks great now! I'm having the same work done next week, hope mine turns out as well. Using restoration design metal here too. Tom
    Tom White
    NSDQ
    Jul 2006
    Corvallis, OR
    Quote Originally Posted by NYSport View Post
    Make sure they have a good spot welder. Ours is expensive and we had special arms made for it to fit in the trunk. The RD parts aren't epoxy primed so we do that first on the under side to prevent rust. And of course weld through primer which is the gold color you see in the picture. Also, don't forget the support brackets under the gas tank lateral support panel that help strengthen where the control arm bolts go. Some don't realize they need those.
    72S, 72T now ST
