Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Interstate batteries no longer available?
    Member lee88's Avatar
    Oct 2012
    New England, USA
    I went to my local Interstate store to get a new pair of the small 12V batteries that fit our long hoods. I've seen them with both "911" and "U911" part numbers. But Interstate store said they don't carry these anymore even when ordering through central warehouse.
    Anybody else found these to be NLA? Interstate store recommended another battery but not sure the dimensions would actually fit the battery boxes.
    https://www.interstatebatteries.com/products/mtp-67r
    I know I can go the Miata AGM route or Porsche/Moll or whatever, may ultimately have to do that. But I've bought these Interstate ones many times before and overall have had a good experience with them so was trying to find them.
    Out driving new & old Porsches and non P-cars
    I have a stocking warehouse distributor a couple miles away I have dealt with for years. That would suck if they discontinued it. As far as I know that is the only battery that fits in the holes other than a OE dealer battery for triple the price.
    Here are the measurements fwiw:
    Early S Registry #235
    rgruppe #111
    Jul 2015
    Ohio
    That's interesting. I just bought two Interstate batteries from our local guy and he didn't say anything about them being available anymore.
    Maybe your guy just didn't want to bother.......
    They have 911 CCA 300 RC 65 PN on the label. The UPC code is 56489 12534
    Hope you find them.
    I saw a Duralast the other day that is almost the same size.
    V4-DLG it is not a AGM, but maybe they have an AGM version.
    https://www.autozone.com/batteries-s...90541_929292_0
    I was also told my my local distributor that these had been discontinued.
    Oct 2012
    New England, USA
    Quote Originally Posted by STEVES View Post
    Hope you find them.
    Yes what was on my label. Glad you were able to still find a pair, perhaps there were still some in stock in your area there but it sounds like these may not be produced going forward.
    I decided to get the Group 70 Duracell branded batteries some others have mentioned here in the forums. We'll see how they work.
    https://www.batteriesplus.com/batter...group-70/sli70
    Junior Member dca911t's Avatar
    Jan 2018
    Eagle, Id 83616
    What about a BOSCH 0092S40010 S4
    Spannung [V]: 12
    Batterie-Kapazität [Ah]: 44
    Kälteprüfstrom EN [A]: 440
    Länge [mm]: 207
    Breite [mm]: 175
    Höhe [mm]: 175
    Polanordnung: 0
    Bodenleistenausführung: B13
    Endpolart: 1
    David C. Allen
    1970 911T 2.2
    Nov 2003
    Santa Monica CA
    Sithot-- Are you saying Mtp-67R battery will fit? Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Interstate has a MTP-T4 that may fit (8 1/8 wide) 470cca.
Tags for this Thread
