Results 1 to 2 of 2
Thread: Oil line pressure testing equipment
    Looking for 911 oil line pressure testing equipment. Built new oil lines between engine and oil tank and want to pressure test them both before install.
    Anyone got the stuff to do this?
    Hi Chuck,
    i have build a kit that I use to test all of the lines I make. If you are in Southern California you are welcome to stop by. If not I will be happy to send you all the parts to make your own kit.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
