Thread: Correct Koni shock top for 1973 S
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    I have two different shock tops for Koni struts: Which one is the correct one for 1973 S ?
    Name:  Koni shock top.jpg
    Name:  Koni shock top 2.jpg
    911S 1973
    Early 911S Registry #176
    Tom,
    Not sure what's correct... However the last time I did my front suspension on my April '73S my originals looked like the one you've shown on the left..... Here right after powder coating...
    Hope this helps,
    cm
    Hi Tom,
    The cover on the left is certainly correct for Koni on a SWB. Weld bead around the top, rather than a machine looking weld or a spot weld as on the Boge. Chuck's look to be the same as the SWB.
    Best regards,
    Brad
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Don’t know how accurate these are. They came on a 75” set I bought some time ago. .....cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    both shocks on my MY72 have the style on the left. Both are dated 1971. Of curse both tops could have been swapped over but seems unlikely.
    Jan 2003
    The Netherlands
    ok, thanks guys! Now I need to source another one.. Oh, and best wishes to all !
    911S 1973
