Results 1 to 5 of 5
Thread: Where does this wire go?
    Dec 2013
    Connecticut
    Removing the front trunk wiring harness. I thought I had them all labeled, but I missed one. Itís the black with whiteish marks wire shown here. It comes off the harness at the same place as a green/white wire which connects to the Fuel and Oil gauge. The wires at the end of the harness shown go to the oil pressure and temp gauge.
    I initially thought it was to the Tach, but that already has a black/white wire that comes off the end of the tach harness with all the other wires for the Tach.
    Any thoughts on where the black/white mark wire goes ?
    1971 911S
    1971 911S Coupe - Gemini Blue
    1974 914 2.0 - Yellow
    1997 993 C4S Coupe - Silver
    sure it isn't blk/purple ?
    Dec 2013
    Connecticut
    That’s probably right - purple
    Blk/purple is tach and would be with the other wires you have.
    Dec 2013
    Connecticut
    Thanks Ed - makes sense
Message Board Disclaimer
