Results 1 to 10 of 11
Thread: 1966 headrests
    Mar 2018
    East TN
    1966 headrests
    Having spent about an hour with the search function, I still haven’t found the answer.
    It’s my understanding that 66 headrests were optional. I’ve read where they were also dealer installed.
    These would be the 356 type. I’m wanting a set for my 66. My dumb question is:
    Do the back rests have to have the mounting hardware inside them? I’ve pushed in on my seat backs. There is no hardware inside the seat back to secure the rail guides to. This tells me that with the early headrests, the backs of the seats needed to have hardware installed before covering. So, the Dealership had to either take the upholstery off the back of the seat or install another set of seat backs.
    Am I missing something? In that...not all ‘66’s can have headrests without either new seat backs or tearing the seat apart to install hardware inside the seat. True or no?
    ‘87 911
    ‘66 304307
    S Registry #3791
    David Cate
    Aug 2009
    SF Bay Area
    The “hardware” for the head rests is in your seats. I’ll post pictures tomorrow. You don’t have to
    Remove any seat covers to install the head rests, either
    Jim
    Mar 2018
    East TN
    It’d help to know what im looking for Jim. Thanks a lot.
    ‘87 911
    ‘66 304307
    S Registry #3791
    David Cate
    The picture of the "mount" inside the seatback is from a 356 not a 911/912, although yours may be similar"
    http://forum.porsche356registry.org/...hp?f=1&t=43372
    Option: https://porsche356registry.org/article/103
    Mar 2018
    East TN
    I might have been looking too low. I’ll check again.
    ‘87 911
    ‘66 304307
    S Registry #3791
    David Cate
    Mar 2018
    East TN
    I’d of never found those without that diagram. They’re under some fairly dense foam and higher than I thought. You gotta know what your looking for to know.
    Now if I can keep from butchering my vinyl....
    Thanks for the instructions.
    ‘87 911
    ‘66 304307
    S Registry #3791
    David Cate
    Aug 2009
    SF Bay Area
    Here is a naked 66 seat back. These headrests provide no protection for your head and neck whatsoever.
    Mar 2018
    East TN
    Great pics man. Comfort only, got it. Thanks Jim.
    ‘87 911
    ‘66 304307
    S Registry #3791
    David Cate
    That’s interesting. Despite not liking the look, I’ve periodically thought about adding them for safety - and you are suggesting they won’t help at all? Is that since they will tear off given the flimsy screws? Frame? If bolted or something would they?
    Aug 2009
    SF Bay Area
    Quote Originally Posted by rower View Post
    You have hit upon a few of the reasons and all are valid. Just one look at the headrest pictured in this thread and one can see that there is no way that thing could restrain anything let alone a human skull. There is no structure inside the headrest, at all, and the supports are just thin spring steed that will not support any weight. Adding them for safety reasons is a waste of time and money. You are probably better off without them so you won't have a false sense of security.
    Jim
    62 356B Cabriolet with headrests
