Page 18 of 32 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 316
Thread: 119200154
  1. #171
    Roof metal is done. Body shop boss finished the welding and shrunk and planished the metal. Needs almost nothing, likely high build primer will suffice.
    The smuggler's box is done as well. The Webasto heater steel duct was a sculpture of weld beads. Removed it and made a plate that continues the center tunnel. More room, looks cleaner.
    Fitted the partly repaired floor board on passenger side to determine the spot for the small support with threaded stud at its base.
  2. #172
    Got myself a new toy, I mean tool. Got to try it with the gearbox first. All that dirt scraped off dry, there was up to 1/2 " caked greasy oily grime on it.
  3. #173
    Rear fenders welded on. Doors latch , gaps are consistent. Rear lid aligns. The rear lights are aligned as well, that took some cutting.
  4. #174
    Floorboards. The driver side is being reglued slowly into shape, works OK. The passenger side… See below. I luckily have in the stash some *very* old 6mm plywood from a drawer chest I repaired a while ago, and it served as perfect period correct material. The plywood one can get now has less layers and has too often plug repairs.
    I am also changing the gaskets on the rear quarter windows… I had done that once in the past and knew what was coming, but it does not get easier.
  5. #175
    Dec 2013
    Connecticut/Florida
    Very nice work
    1971 911S Coupe - Gemini Blue
  6. #176
    Yes, in part. He said it took a lot of cutting/moving/shaping to have the lines correct and the rear lights in position.
  7. #177
    Just noticed the stud at floor pan for DS floor board does not show in photo.
    Assume still in plan.
    Great work ....
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
  8. #178
    Good catch. It is in the plans, along with a left footrest.
    Does anyone have a measure refrence for the footrest?
  9. #179
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by GeorgeK View Post
    Good photo on Aase website:
    https://www.aasesales.com/products/g6k-b52-34i-101977
    Some supposed original placements in 911Rs here (looks just like Aase photo):
    http://www.early911sregistry.org/for...l=1#post280003
    1969 S Coupe #761
    Early S Registry #1624
  10. #180
    Thank you!
