Page 24 of 32 FirstFirst ... 142223242526 ... LastLast
Results 231 to 240 of 316
Thread: 119200154
  1. #231
    Love that you saved the wheel George, nicely done.
  2. #232
    Thanks for the good words. I am trying to *not* make the car new. It is 51 years old and counting. While the mechanicals, brakes and body will be redone, I intend to save what patina I can. Door handles, mouldings, sills, steering wheel, rims will be in cleaned, used condition.
    After some intensive conditioning, the leather has become smooth again, if a little checkered on top. Now waiting for the hub extender from the machine shop.
  3. #233
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    That looks great George. Well done.
    '72T Coupe - Sepia Brown
  4. #234
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by GeorgeK View Post
    After some intensive conditioning, the leather has become smooth again, if a little checkered on top. .
    Hours of spirited driving will take care of some of that.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  5. #235
    Feb 2016
    Bordeaux FRANCE
    Confinement has advantages.
    Clutch, throttle, handbrake, speedometer and heater cables cleaned. I had to repair the broken end of one handbrake cable by welding a bolt on end, and drilling it for the safety clip.
    I have the contact piece for the clutch fork, but can't find the bolt. M7 is correct? it is between M6 and 8 and has a 1mm pitch.
    I took apart and cleaned the front calipers. no mangled threads, no broken bolts. This raised a few questions:
    Restorable? the pistons are gone, but the caliper bodies?
    Date codes correct for a '69? one seems to fit, the other I can't decode.
    Your two calipers are not exactly the same. The casting are a little different, note the circules.
    There is 3 variations, you have first and second, the third one is light yellow finish.
    I have a spare one, maybe for a look, trade or sale.
  6. #236
    Hi J-R,
    I noticed that. The calipers are en route to Eric and Marquis at PMB in Utah.
    You can PM me in case you'd have a correct early caliper for sale/trade.
    George
  7. #237
    Feb 2016
    Bordeaux FRANCE
    Hi George,
    I have a second generation caliper for sale, not a 69 one. Let me know
    As I have on my 69E sportomatic AMAG delivered with PMB pistons in driver conditions.
    Nice work on your steering wheel stitching, I have to do the same on the spokes
  8. #238
    Any üpdates?
  9. #239
    Well, yes, but no pics.
    -Steering wheel is assembled, with the extended hub. Found the correct half round headed rivets, and used M3 bolts to secure the horn holding ring.
    -Frank sent me the last missing parts: 2 driveshafts, 2 sway bars (15mm), windshield mounted mirror, pedal cluster and handbrake mechanisms. He can be… interesting on the forums, but he is a straight and fundamentally honest man.
    -Realised I am missing all the clips that hold the header bowden outer cables on the fresh air setup in the front trunk, so if anyone has some to spare…
    -Totally unrelated, but got my paws on a hodge-podge of a VW Beetle (like Johnny Cash's song, it's a '59, '60, '61...) that I am looking into rebuilding. Man, Beetle parts are cheap after a steady early 911 diet…
    -Unrelated #2: the 964 has got its historic vehicle papers, meaning it only has to go through inspection every 6 years. It has to be 100% original (which it is), and remain so. We filled the AC after I renewed/replaced every part and it works perfectly. Now to sell the car...
    -Front brakes are in Sandy, Utah.
  10. #240
    Jun 2012
    London, Ontario, Canada
    The clips are available from the dealer. 901.571.919.00
    Only issue is that they are silver, so you will have to yellow cad plate them.
    Ravi
    Early 911S Registry # 2395
