Results 1 to 10 of 15
Thread: Heat exchanger experts, question
    Aug 2013
    Westlake Village, Ca.
    Other than a '65 what year heat exchangers will be the same as a '66? Thanks
    Scott
    303581
    Quote Originally Posted by Bradford View Post
    All of them thru 74 are essentially the same and can be bolted right on your 66 engine. Now the heater box police can start to pick nits.
    Aug 2013
    Thanks Jim
    Can anyone tell me what this small tube (circled) is for? I don't have this on my '66.
    Scott
    303581
    Thanks Jim
    It is for a rubber hose that goes to a MFI pump for heat. Not needed for carbs or CIS. Can be blocked off.
    Aug 2013
    Thank you Jim
    Scott
    303581
    The pre-heat tube would of appeared on 69 MY.
    Jan 2019
    Melbourne/Australia
    Does anyone have a photo for a 911T engine? Anyone have a pair of used ones for sale?
    Jan 2019
    Melbourne/Australia
    Thanks for the link mate but I'm trying to source cheaper ones as the postage cost will be a killer...Cheers!
    My '67 Normal had the original heat exchangers with "chokes" in them. I still have them but SSI's are on the car.
    FWIW: Porsche experienced cracking issues in some heat exchangers noted in a bulletin dated December 16, 1966. The bulletin is 2 pages and gives a description of the work scope and labor time.
    Here is an excerpt regarding the seriousness of the problem:
    "The introduction of such gasses into the passenger compartment may be unpleasant and, under certain circumstances, will present a significant safety risk. Therefore, the program described below must be carried out as quickly as possible"
    In another bulletin Porsche also allowed customers to upgrade to the 911-S heat exchangers however they charged for this because performance was increased.
    The cost was $65 each. Porsche claimed an increase of 10-12 DIN horsepower with the "S" heat exchangers.
    The heat exchangers in question were: 911.211.011.00 left 911.211.012.01 right.
    The new heat exchangers were: 901.211.011.01 left 911.211.012.02 right.
    The "optional" S heat exchanger part numbers were: 901.211.017 left 901.211.018 right.
    Early S Registry #235
    rgruppe #111
    Quote Originally Posted by al agustin View Post
    I would strongly advise adding location info so that we can avoid wasted effort. Long distance or cross border shipping is a deal killer.
