Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 911 2.2 s
    Nov 2018
    Malta
    911 2.2 s
    Hello
    I am looking at a 911 2.2s presumably built in 1970
    I have the following vin plate and also a number stamped behind the dashboard.
    I wish to know if these numbers ( which are different ) are as they should be , i.e. is the chassis matching the vin plate
    Vin # 9111300663
    Dashboard stamp # 103 2631
    Also any other information welcome.
    Thank you
Size:  70.2 KBName:  50531523_2516809588334146_2114942025122971648_n.jpg
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    I am having a hard time reading the aluminium plate - you should also look at the vin stamp in the trunk
    'IF, as you say, the VIN stamp reads 911 130 0663 that would be a 1971 model year 911S NOT a 1970 so definitely NOT made in 1969
    However the production number (which will never match the vin in a LWB car and only Porsche can tell you if it is an exact match) CANNOT POSSIBLY MATCH THIS VIN for be for a 1971 (or 1970) car
    It is a production number (thus a shell / tub) for a 1973 911 Coupe
    It can be decoded as
    1 911
    0 Porsche built coupe
    3 1973 Model year
    2631 series number for all coupes (T,E,S and RS) built in that model year
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Nov 2018
    Malta
    Quote Originally Posted by HughH View Post
    1 911
    3 1973 Model year
    I am terribly sorry , my mistake built in 1970
    Dec 2004
    Melbourne Australia
    even so it is a 1973 MY shell so absolutely not a match (i cant open those attachments in your last post)
    Hugh Hodges
    73 911E
    Melbourne Australia
    Nov 2018
    Malta
    1 911
    3 1973 Model year
    Hello Hugh,
    Whilst near the car I checked another one also the same numbers.
    Are you sure the same criteria for these numbers which are as you say for SWB , the same in LWB ? Attachment 480751Attachment 480752
    Nov 2018
    Malta
    will come again ;-)
Size:  69.0 KBName:  50778301_2293918547519837_6798478744718671872_n.jpg
    Nov 2018
    Malta
    and this , sorry .
    They are from another car Name:  50815229_311023789545962_6615116493384318976_n.jpg
    Dec 2004
    Melbourne Australia
    I still cant open those attachments
    SWB cars did not have a separtae production number stamped - the "dash number" was the same as the vin
    When Porsche moved to a "new and improved" ordering and tracking system for their cars they also incorporated a production number that was separate to the VIN and tracked the order through the production process
    The "upgrade" occurred over several years and the 1969 model year (the first year of LWB cars) was the first to have the production number process
    it was refined over a couple of years (and at that time Kardexes were phased out and replaced by a primitive computer based system
    the production # can be decoded as follows:
    format XYZabcd
    X=0 replacement body
    X=1 production body
    Y=0 coupe
    Y=1 targa
    Y=2 Karmann coupe
    Y=3 Karmann 914/6 targa
    Z= last digit of model year beginning 1969
    Z=9 1969
    Z=0 1970
    Z=1 1971 and so forth
    abcd is the sequence #
    EDIT I can see them now
    Hugh Hodges
    73 911E
    Melbourne Australia
    Dec 2004
    Melbourne Australia
    that set are production number 113 1083 or a 1973 model year 911 Targa and the 1083rd one ordered to be built
    the vin 9113510292 is for a 1973 911 T Targa and the 292nd of those made that model year (but with carbs not MFI or CIS - the 5 in the sequence for a T-Vergaser)
    therefore they may be a match but only Porsche can tell you
    Hugh Hodges
    73 911E
    Melbourne Australia
