Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: ‘71T 2.2 HP upgrade options.
    Senior Member M_deJong's Avatar
    Jan 2011
    DFW TX
    Quote Originally Posted by geneulm View Post
    if you HAVE to rebuild, there are some pretty proven, reliable combinations that will get you into the 170s and have a very nice motor... and nowhere even close to overmotoring the car. And keeping the case you have w/out boatloads of machine work, twin plugging etc.
    Starting with a 2.4 by adding long stroke crank and rods from a 2.4/2.7
    E or solex cams.
    New 2.2 (still will be a 2.4) piston/cylinder combo to get you into the 9.5 range.
    03-19-2015 08:51 PM
    This is the route I took in my ‘71 searching for more fun... and torque. I had a 2.7 crank and rods so that helped the decision. I went with Biral cylinders bored to 85mm and new 9.5 pistons, which I think are more like 9:1 in use and E cams. Result is a more revvy engine with gobs of torque, but not a high rpm screamer since I kept the small port heads.
    Mike de Jong | PCA - Early S - R Gruppe | '71 911T 2.4 Tangerine | '74 911S 3.2 Ice Green
    Mar 2013
    Einsiedeln, Switzerland
    I bought a 79 3.0SC engine. Quick and cheap... And then started tuning it. Its now a 3.2SS running 46 PMOs
    Regarding the point about S calipers. Are they actually any better, or just lighter?
    Paul
Message Board Disclaimer
