Thread: 911 Carrera RS Rear Cross Panel
    Hi,
    Can someone be so kind and let me know
    from which date onwards and for which 911 model(s)
    1.rear cross panels were used which had on the left side a small rectangular bulge next to the
    larger indention (with the "Alternator Sticker"):See Image
    2.rear cross panels were used which showed on the inside of both ends not a curved but a rather angled line?
    See Image
    Thank you for your help
    Nov 2003
    Santa Monica CA
    I can tell you that rear panels that have a angled line at the ends are always replacement panels on early 911's (1964 to 1973 cars). Either the originals have been damaged or severe rust was present. I concentrate on the early 911, so I will say with caution that the angel line panel was used on later production 911 (post 1973 cars). But I am not sure when. The angel line panel was all that was available to use as a repair for the rear cross member, so they were used on all cars. I have no data on the yellow car. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Pretty sure the bulge started in 73
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    The little raised bump (I believe to allow an alarm switch) was added in sometime during the 1973 model year. i am not sure when BUT I think it was in 1973 and probably not at the start of 73. it appears in cars made as early as April (and maybe before that) but it is hard to know if panels you see on CURRENT cars of that vintage have not been replaced at some time. I have never seen any paperwork detailing when the change was actually made - It may have come in at about the time the fan strap went from two bolts to one
    I have looked at photos I have of various cars (E's S's and RS's Coupe and targa) made between march and may 1973 By may all seem to have them (but a very small sample) In March I did no find any and April was mixed with some having them and some not. I have many more RS photos than others and there are a couple in the low 0800 vin (March) that have them BUT mostly dont until over 1000 (mid april) however the low 0800 cars were treated hard when new and have been extensively restored (and probably repaired back in the day) so are not likley to be original panels
    so best guess is a soft transfer in April for all cars (T E S and RS) but as parts ran out so there will be a wide crossover in Vins during that month (especially as they were not produced in vin order)
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
