Results 1 to 7 of 7
Thread: Cibie plastic light retainers for Hood lights / fog lamps
    Jan 2019
    Chicago IL
    I am restoring a car and the car had Cibie lights prior to the restoration and the owner wants to keep them. The only problem I have is with the plastic retainers that hold the bulb to the housing, the bulb pops out easily. One side snaps in the the mounting ring and the adjusters snap into the other side. I can't find them online anywhere, but maybe I just don't know where to look. Any help is greatly appreciated! I don't know how to post photos correctly, so I made a folder in Google photos and included the link
    https://photos.app.goo.gl/yt31mLwi6MRaeiGM6
    Currently restoring a 1973 Porsche RS M471 back to factory original condition
    You should contact René Kemer in Nederland, he maybe has these available.
    #rennfrog
    Jan 2019
    Chicago IL
    Quote Originally Posted by OliveR View Post
    I did a web search and couldn't find him, do you have any more info? I appreciate the reply
    The flange on the plastic retainer goes between the body and the light ring. This prevents it from being pulled out when the light is removed.
    Jan 2019
    Chicago IL
    Quote Originally Posted by JimmyT View Post
    Exactly. Mine go in and come right back out with very little effort. My lights will come loose as soon as I hit the first small bump in the road. The other side doesn't grip the light very well either. Not really unusual for the age, the parts are not as flexible as they once were many decades ago
    Senior Member Soterik's Avatar
    Seattle WA
    This auction on German ebay shows the trim ring with the plastic mounts in the ring. I have the outer chrome trim rings in stock and the mounting studs, but we (Rene and I) didn't make the plastic piece as a separate item to offer. I got the last of the spare parts a few weeks ago, and there were no individual items like this available. So, if you've got a broken plastic retainer you might have to get one from that German retailer, but if you need me to check my stock let me know for that entire ring.
    https://www.ebay.de/itm/Cibie-Repro-...LwS:rk:11:pf:0
    Eric
    www.autoforeignservices.com
    Early S Registry #259
    RGruppe #60
    57 Speedster, 59 Cab, 59 Coupe, 63 Coupe, 65 Cab, 67S coupe blue, 67S coupe red, 67S coupe green, 67S coupe bahama, 67S targa red, 67S targa silver, 66 912 bahama, 67 912 green, 67 912 white, 67 912 targa blue, 68 912 targa blue, 68 911L "factory rally kit 901/30 motor # matching"......
    There's always room for one more person under the bus....
    Jan 2019
    Chicago IL
    I looked at your message again, and I see that you are telling me that I installed it backwards. Problem is that its so loose, that if I install it that way, the light just pushes it out of the hole when I try to install the light. I tried the correct way first and couldn't install the lights at all! new plastic is needed. Once I have new plastic, I will try the other way again. Thank you for the information!
Message Board Disclaimer
