Results 1 to 9 of 9
Thread: Numbers anomaly
    May 2011
    Chelsea, Québec
    Numbers anomaly
    Hi
    I followed a thread on the sale of a '66 normal:
    http://www.early911sregistry.org/for...66-Porsche-911
    and noted that the CoA provided shows the VIN 304540 with a 'production completion' date of 21 June 1966.
    My car, VIN 304598, 58 cars after this one has a CoA production completion date of 26 May 1966 - 4 weeks earlier than 304540. (My Kardex states completion date is the same, 26 May 1966).
    304540 engine number = 908117
    304598 engine is c.200 before that...
    304540 transmission number = 232013
    304598 transmission is c. 1,600 before that...
    304540 webasto number = 005 148
    304598 webasto number is c. 600 before that...
    Name:  IMG_5226 pixel.jpg
    Seems a little strange...
    Any historians or numbers guys (DaveP) got ny ideas or is this scale of anomaly unremarkable?
    Cheers
    Stephen
    Member #1616
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Stephen,
    We all are aware that CoA's are reknown for inaccuracies but I must say that it is an interesting discovery that you have unearthed.
    May be a simple typo as I doubt they were not waiting for the noted spare parts bag to arrive for the 304540 car.
    Mark
    May 2011
    Chelsea, Québec
    I thought maybe DaveP could check the Kardex for 304540 to see if the COA matches... mine does... and the factory confirmed the details too...
    Member #1616
    Aug 2011
    Eugene, OR
    It has been my understanding that if a car failed any of the QA checks or the road test for any reason, it went back for remediation which could take days or, perhaps, weeks. In that case, completion date could be way out of sequence.
    - Arne
    Could it be due to the colour?
    304540 COA just states 'Brown' - no colour code, whilst yours, Steve is a factory Slate Grey, code 6601.
    Perchance 304540 was taken off the production line and put into hibernation to await a slot for being sprayed a 'colour to sample'. It would be interesting to see the actual colour of 304540
    Just my 2 pence.
    Looking for 1967 911 trans 130830/902-1
    May 2005
    Oroville, CA
    When did the number plate move to the slam panel? I thought that was 67? Maybe late 66?
    Oct 2008
    Burford, ON, Canada
    First, the completion dates on the COA are FALSE; at best it is the invoice date from the factory, and at worst it is the delivery date to the customer. Both are taken from the Kardex. The Kardex may have both dates, one of the two or neither. In general the earliest Kardex date can be weeks after completion date. Numbered bodies were delivered by Reutter to the factory, and not always in serial sequence. The completion of the cars was not in serial sequence. The engines, transmissions and Webasto heaters were pulled at random from a large stock, and usually in first-in last-out sequence.
    I believe the VIN tag moved to the slam panel between 303111 and 303145 around Dec 1 1965 going by Kardex dates.
    Yes strange things happen - as per Kardex engine in my car is six months earlier than one would expect.
    Membership #3255
    301022
    revivem.co.nz
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    "....Could it be due to the colour?...304540 COA just states 'Brown' - no colour code...."
    this is interesting, .....
    what does the tag has stamped on it and the Kardex would really help.
    938 Havana brown
    6411 413 Togo Brown
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
