Results 1 to 10 of 19
Thread: Jan 1966 does this look correct ??
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    I would like to know if the ""GOD"S"" can knowledge me on this 2.0 Jan 66 engine.
    Solex and duel Pierburg,,
    Anything stand out as abnormal ???
    Fuel lines etc are a gimmie.
    I am purely seeking advice.
    Thank you all in advance.
    Name:  Image 21-02-19 at 12.03 PM.jpg
    Mark
    Does the emission sticker on fan strap have a year date? My 65 has a different sticker attached to the snorkel, but this may have changed with 66 model year.
    John Schiavone
    Connecticut
    Senior Member VA_alfa's Avatar
    Jan 2013
    Shenandoah Valley
    It’s hard to tell from the photo but it appears that your cams are spraybar lube instead of center lube. I can’t see the oil lines connecting to the chain covers. If I remember correctly the January 66 cars still had center lube cams.
    EDIT: center lube cams ended on engine 903069 in late 1965. Yours is correct in this regard.
    Last edited by VA_alfa; 02-26-2019 at 01:38 PM. Reason: Edited to correct wrong info.
    Alex in Virginia
    Looking for:
    ward to driving my car!
    Early 911S Registry # 2863
    spark plug wires, snorkle sticker as mentioned, no bendix decal on fuel pump, no hot air hose to snorkle, red ignition coil, later style clamps on air hoses, fuel lines and filter as you mentioned, look like later plug connectors.
    Oct 2010
    Southern Ca.
    The big problem is the hard fuel lines that go over the fan housing . You now have rubber fuel lines instead connecting the fuel pump to the right carburetor and right intake manifold float bowl .
    Feb 2017
    Auckland NZ
    Thank you all for your observations and all are noted gratefully.
    She is a matching 'cutie' and coming home on Monday.
    Name:  Image 21-02-19 at 12.07 PM.jpg
    Mark
    Banned
    Nov 2004
    Scottsdale, AZ
    When you say "home", assume your home?
    Congrats.
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    Congratulations mark. I saw it on trademe last night. Looks a great pick up.
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Nov 2002
    San Dimas, CA
    If it's any help, here are hard fuel lines along the fan shroud of my '65:
    Name:  2016-12-21 18.44.56_PS.jpg
    Fabricating the fuel lines shouldn't take a whole lot of tooling.
    Here's a photo of an original snorkel sticker:
    You can get a snorkel sticker from Aase Sales
    Or from Car Bone
    I personally prefer the Car Bone snorkel sticker. If you get to the Lit Meet, chances are good both Aase Sales and Car Bone will be there.
    Finally, here's the only original color photo I have of a very early 911 engine (from a March 1965 brochure):
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Nov 2002
    San Dimas, CA
    You can get fuel line ferrules from Brad Davis of HBD Products www.911rennen.com.
    I don't think he has the hard fuel lines, but who knows, maybe he can help. He can supply the Center Lube Cam Oil Lines.
    Jim Alton
    Torrance, CA
