Results 1 to 10 of 11
Thread: cost to restore fuchs?
    What would it cost to restore 7jx15 wheel? It has a couple nicks or sale as is? Thanks
    Jul 2008
    South Florida
    https://www.fuchsrestoration.com/pricing
    Someone familiar with Harvey's pricing may pipe up, too.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Oct 2010
    Southern Ca.
    I think around $325.00 per wheel is a good estimate for Harvey . Harvey is actually a good deal if you are prepared to wait . No one else comes close , but if you won't appreciate the authenticity maybe someone else .
    wheels
    Quote Originally Posted by Richy View Post
    Thanks for the quick replies, good info. LA
    If just one wheel, I'd sell as is—as most people will want wheels to match and it's therefore best to do wheels in batches. If I was a buyer, I'd want to match it to other wheels in one shot.
    Aug 2011
    Eugene, OR
    Quote Originally Posted by stout View Post
    This. Sell it as is.
    - Arne
    Dec 2010
    Southold, NY
    Quote Originally Posted by acar24 View Post
    It has a couple nicks . . .
    Your idea of a "nick" is quite different than mine.
    Quote Originally Posted by ejboyd5 View Post
    I agree with Ejboyd. More than a "nick" and will drive down the value of the wheel. From the picture the rim "nick" looks like it will need to be welded. If so it will not be invisible when the wheel is anodized.
    Put it in our classifieds with your price and photos... Good luck
    cm
    Quote Originally Posted by Saskia View Post
    If the filler material is the same alloy as used by Fuchs, then the anodized finish should match with the existing wheel, but what are the chances of that happening? Nil. I had Al Reed refinish a set of Kelsey P2 wheels (17" barrels with welded Fuchs centers) in an RSR finish. After bead blasting the original polished finish, the former valve stem hole (plug-welded by Kelsey) and the surrounding wheel had distinct color differences. Anodizing wouldn't have made a difference. I ended up ceramic coating all bead blasted surfaces with a close matching RSR gray/silver.
    Sherwood
