Results 1 to 9 of 9
Thread: Why Might My Car Catch On Fire?
    The work of a stereo install shop. I've heard of harnesses drilled through during aftermarket alarm system installations requiring an entire body harness replacement per Porsche so the warranty wasn't voided. Not a cheap mistake.
    This is a $hi7-show shared by one of ours who is making amends for the egregious ground attempt.
    Early S Registry #235
    rgruppe #111
    Jul 2008
    South Florida
    What the... whoever is responsible for that needs to be forcibly directed into a simpler profession.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Yikes!.......
    Peter Kane
    '72 911S Targa
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by Bullethead View Post
    Crash test dummies?
    Too much trouble to get a lug to fit the factory grounding stud?????????
    What's been seen...
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Ohms my God
    Just lovin the yellow heat shrink insulator ""un shrunk"
    Watts were they thinking,, ??
    Mark
    Aug 2016
    NE Ohio
    Darwin has a special place reserved for people that do this type of work period.
    Dec 2003
    West Los Angeles
    Too bad. One of the first things you learn in dealing with any electrical stuff is to have an absolute miimum number of grounding points. That stud could have easily accommodated the other two wires, which I'd prefer to have seen solder-dipped, crimped to the ring terminal, soldered again and sheathed in shrink-wrap tubing. Using sheetmetal screws with countersunk washers meant for upholsery... lame. At least whoever it was cleaned off the area for a better electrical contact.
    techweenie.com
    Dec 2010
    Southold, NY
    Doesn't look like Porsche bothered with all that soldering and sheathing either. After all it is a ground connection. To me, it would have been easier to use the existing stud rather than breaking out the washers, sheet metal screws, etc. This installer was probably used to working on cars that did not provide a factory ground point so he fell back on his usual practice and drilled a new hole in the body where needed. Perhaps he also did aftermarket air conditioning work in his off hours.
