Results 1 to 10 of 10
Thread: Tunnel Variations and adaptability?
    Guys see photos ...
    My 71 tunnel was rusted beyond salvage so solid donor is getting ready to install weld etc.
    Photo 1 is from my 71 and Photo 2 is different in layout as follows..
    - larger shift rod opening
    - oval shaped speedo opening
    - emergency brake and heater control re stacked and not side by side
    - fuel lines are slightly different
    So what year/s are the donor tunnel from ?
    And thoughts on adaptability?
    Happy to make modifications to the donor using original 71 components but would rather not
    Making more complicated than necessary.
    Thanks for input
    Frank
Size:  113.5 KBName:  07676FE2-E4F9-4A09-93A2-B66F114B022B.jpg
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    I believe the top one is for a 901 due to the lip for the trans shift boot on the back of tunnel. The bottom one is for the 915 style shift boot that goes thru opening and fits on lip in tunnel. To further delineate the top should be for a 70-71 car since it has the tubes for the charcoal cannister system.
    Ed
    Thanks for info.....
    I am also attaching photo of my 73.5 with the 915 style tunnel components it also has the tubes for the lines to carbon filter in trunk. Posts have stated the 915 used from 72-86.
    Just find it unusual that the emergency brake,heater , speedo cables are respostioned after 71 starting in 72
    Would like to know more about why the layout change.
    Guess I will plan to keep the 915 tunnel as is .....unless there are reasons to change when using 901 trans?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Oct 2010
    Southern Ca.
    What year is the replacement tunnel ? It looks like it may have a tube for the brake booster vacuum line , could be used for one charcoal canister line ?
    Richy
    Not sure the year the donor tunnel ......my count of left side tubes ( not including the parking brake ,heat , accerlator and clutch ) there would be 4 tubes available....
    Attached is a 70S tunnel .......2 are fuel supply and return
    Thanks again for input
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Aug 2011
    north of the 49th parallel On Can.
    Can any someone inform me what #6 & #9 are for
    6 is throttle, 8 is speedo, 9 is harness .
    You are a walking encyclopedia !!! So cool to have you here...
    Peter Kane
    '72 911S Targa
    Thanks Peter,,,but actually his answer was also at post #3
    LOL...my comment still stands. I learn every day...
    Peter Kane
    '72 911S Targa
