Results 1 to 7 of 7
Thread: 911T Engine-Fuel Recommendation
    Jan 2019
    Melbourne/Australia
    Can anyone please advise what is the safe fuel you use in the US for a 911T engine. My car has finally arrived and I am just about to get my very first Aussie tankful of fuel. We have basic unleaded 91,95 or 98 Octane fuel or petrol as we call it here. Thanks everyone!
    Aug 2011
    Eugene, OR
    Depends on which T you got. The 2.4 was designed for lower octane fuels and can probably (if stock) do fine on 91. The 2.0 or 2.2 motors need higher octane, probably 98.
    Even in a 2.4, if there is any possibility that the compression has been bumped up during a rebuild, higher octane is safest.
    - Arne
    Jan 2019
    Melbourne/Australia
    Thank you!
    Nov 2016
    SoCal
    Higher octane fuels safer probably especially in warm weather. Can help prevent preignition.
    Do you have ethanol in your fuels? That can wreck havoc on these old fuel lines even modern rubber ones.
    If it knocks, you need higher octane. Anything else is overkill.
    Peter Kane
    '72 911S Targa
    The Netherlands
    Stay away from the E10 (10% ethanol) if that is applicable down under.
    Cees
    My 71 gets all the 87 it wants
