For sale
-79 3.3 turbo engine
either long block or full
has been rebuilt during last winter
all new bearings (glyco)
new chains and new hydraulic tensioners (porsche)
crank is polished and con rod neck nr 5 is grinded to -0,25 size
con rod refurnished with new top bushes
heads done, seats and guides, valves (old) are grinded
new piston rings (old pistons and cyls measured on specks)
old std camshafts with its old rockers
Victor Reinz seal set all new
correct seal clues used (black, red & green) to seal the block
now fully ready on long block state, take two weeks to full ready is some one prefer full one
alternator will have new bearings and checked
old wire harness wrapped newly with right old type of cotton tape and plastic over it
old distributor (already checked)
the engine cover has seen better days, color is shaded, but no major cracks on it can paint it if wanted but my self prefer original even looking wear on it
engine tin ware are zincked and painted to black, new air paper pipes and new air tubes to chassis (correct orange ones)
air feeding holes blocked on exhaust side
fuel head are under maintenance (new seals and checked)
injectors are tested for spray pattern and correct opening pressure
old exhaust headers, intercooler and pipes, all are washed and can be painted
Turbo is kkk k27 one it is used, but in good condition, no play on shaft no oil burning
old original waste gate, valve seat machined and new rubber on air side and 0,9 bar spring (std can be fitted is needed), new bolts on it
B&B stainless steel dual out exhaust silencer
can take as part of deal a 2,7 engine or 3,0 engine with problems (no blown rod thru block) pricing depending the condition
price for plain long block firm 12t€ full engine firm 18t€
flywheel (old)+ clutch (new) + pressure plate (old) can be purchased at extra cost
+ actual shipping & packing cost to pallet
(roughly transportation is about 350-400 eur to Europe with insurance to us around 500€
weight about 250kg total with veneer pallet box)
will put pics & engine number next week when back to shop, now in Weissach on Porsche resarch zentrum
