Just had my new Vredesteins mounted up and the spare doesn't fit in the well - am I going to have to deflate it and carry a 12 volt compressor with me or am I missing something?
they are 185/70 - 15
73 911S Targa
Is the jack or tow hook in the way? Looks like you need to slide the spare tire end closet to the front of the car under the latch box first.
Mike Fitton # 2071
2018 911S Carrera White
if your car would be a 64-67 (its not... right?)i`d say it`s the bracket i marked with the arrow...i think with the introduction of the 15x 5.5" fuchs rims this reinforcement bracket changed to an asymetrical type to give more space to slide the wheel in.....but i have seen exeptions on LWB´s for what ever reason.any close up pics of this area?
slam panel replaced?
i`d try to loosen the 3 bolts that retain the fuel tank and try to push the tank back --maybe it slides a few mill and BINGO
I have absolutely no thoughts on this subject. Sorry. I'm just happy that I'm not the only one that weird s**t happens to.
Good luck!
So my first question is whether you have had a stock size tire in that well before? Is it the original fuel tank?
- Arne
Car had a CN36 185/70-15 (could have been original) in it before with no issues. Car is a 1973. Appreciate any input -
73 911S Targa
This happened with Vredesteins on our old VW bus... the overall diameter was too large to fit the spare tire well.
In your case, 185/70 x 15 CN36's are 24.88" OD, the Vreds are 25.20". A mere 1/2" difference, but it's enough.
Russ
ESR # 1537
'62 356S Notchback Hotrod
'67 S Das Geburtstagsgeschenk
'68 T Targa Sportomatic
'68 L SW Targa Sportomatic
'70 914/6 GT
You could try deflating it. Might still be a snug fit since steel belted tires don't grow that much when inflated.
I haven't been much of a fan of Vredsteins for quite some time, this would be yet another reason to pony up for the CN36 or XWX.
- Arne
