Results 1 to 10 of 16
Thread: clear battery pole plastic covers
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Looking for 6 clear plastic covers for the battey poles
    Picture of the 73T 700miles car shown here years ago.
    In spite of the picture, a heavy shaped rubber block belongs over the + battery pole and cable end. Looks like it might be under plastic cover. IMO the plastic cover doesn’t belong. Frank come in, over. G
    Here is pix of rubber block. One in place the other upside down.
    May 2006
    CT
    The low mileage, original '70S car shows what looks to be a black plastic cover. It could be the "rubber block".
    Is there a source for these?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    May 2006
    CT
    I just checked and Stoddard shows them. I learned something new....Thanks
    The PET show (2) of these so I assume (1) for each positive terminal??
    Tom Butler
    1973 RSR Clone
    1970 911E
    Mar 2016
    U.K.
    My OPC dealer thinks that the plastic cover goes on top of the rubber block. The rubber block alone has carbon content so if it rubs against the chassis and gets damaged you can get a short (this happened to me). The plastic cover over the rubber block should stop this.
    May 2006
    CT
    Quote Originally Posted by 911GP View Post
    That’s what the PET shows. The rubber Block is covered by a plastic cover. The PET shows this only on the positive side, not the ground side. I’m curious if both need the rubber block and the cover.
    Tom Butler
    1973 RSR Clone
    1970 911E
    If someone has one of the clear ones, maybe use it as a basis to copy one with a 3D printer...
    I'm with gled49 , some of the original Porsche batteries simply did not have these clear covers . The 700 mile '70S of course has a newer battery that has the cover . Bottom line - the cover came with the battery , it was not a Porsche part .
    The image from edition II 9.72 factory spare parts manual (original paper copy so not muddied or having doubts by suspercession etc that can confuse originality questions if using www PET as a snapshot in time --although probaly not different in this instance ).
    Vintage image in an early 911 all historical publications courtesy of Porsche
    Seems likley many got lost or tossed due to battery changes over the years. When next at car storage I'll post picture of ones for my 12/72 car although someone will probably beat me to it if someone has an original pair of the positive terminal covers handy.
    Hope this helps
    Paper version sometimes misleads e.g.in this case not totally accurate data point for all model quantities since some homologation RS from early series depending on conversion order only had one battery!
