Results 1 to 10 of 12
Thread: Throttle Bodies and Stacks
    Feb 2007
    Thousand Oaks, CA
    MFI Throttle Bodies and early Mag Stacks (Bore Top 52mm / Bottom 39mm by Aaron Burnham)
    Price is $2900
    Tom Ching
    69E Burgundy
    Mar 2017
    Baltimore
    What are the numbers on both? Thanks!
    1970 911S
    1999 early build Carrera
    Feb 2007
    Thousand Oaks, CA
    Sorry for the slow reply. The tb’s and stacks are from a 69E MFI system. I will get the numbers ASAP.
    Tom Ching
    69E Burgundy
    Feb 2007
    Thousand Oaks, CA
    Here are the numbers from the tb's and stacks.
    Tom Ching
    69E Burgundy
    Mar 2017
    Baltimore
    These are wonderful Tom. Numbers are correct for a 69E. Sadly looking for a 70s but they will no doubt find a great home!
    1970 911S
    Senior Member prez!'s Avatar
    May 2010
    Atlanta GA
    Quote Originally Posted by snwalker View Post
    These are no longer correct for 69E. They have been opened up for hot rod build I would expect Aaron opened up the stacks as well.
    R Gruppe #631
    Early 911S Registry #1825
    1973E Coupe
    Mar 2017
    Baltimore
    Quote Originally Posted by prez! View Post
    True true. Meant the numbers are correct...
    1970 911S
    Feb 2007
    Thousand Oaks, CA
    Hi, yes there are originally from a 69E MFI but have been bored 52mm (top of the stacks) to 39mm (bottom of the throttle bodies). They are for heads that have been modified as well. Correct, they were built by Aaron Burnham. Thanks for the questions and comments.
    Tom Ching
    69E Burgundy
    Feb 2007
    Thousand Oaks, CA
    Bump . . . These are still available. Negotiable.
    Tom Ching
    69E Burgundy
    Feb 2007
    Thousand Oaks, CA
    Bump for new price
    Tom Ching
    69E Burgundy
