Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Under Body, Floor & Engine Bay Colors
    Hi All,
    I would appreciate some help with under body, floor and engine bay colors.
    When did these areas go from being painted black to being the same as the external color?
    Thanks!!!!
    Whilst on colors.... When did the engine fuse panel change from black to silver?
    Thanks!
    Nov 2015
    What year is your car?
    I know 1969 had black frunk and trunk.
    I also know that 1972 had body color frunk and trunk.
    I am not sure about 1970 or 1971.
    I am also not sure about the body color exterior floors....
    www.tcspeed.com
    Member dogLeg's Avatar
    Aug 2015
    1970 is body color floor & front trunk - however eng compartment is black (over body color).
    Tim
    1970 911T
    #3257
    Nov 2016
    Munich, Germany
    Quote Originally Posted by dogLeg View Post
    1970 & 71 is body color floor, frunk & trunk
    Well, not quite. My MY70, build date somewhere 10-12/69 is body color frunk & exterior floor (except some areas) and engine bay black. As is the 1970 700-mile "S" mentioned in some thread here years ago and photographed by Dave:
    https://www.flickr.com/photos/807244...7630169538658/
    Quote Originally Posted by 911AUS View Post
    Thanks!
    Interested in this as have a spare one squirelled away in black that is probably not correct for my MY 73 car.
    When you say body color, I presume you are referring to exterior panel color?
    Dec 2010
    Southold, NY
    Three consecutive posts (3, 4, and 5) using the term "frunk." It must stand as some sort of record.
    My early '72 (8/71) was body color in the "front trunk", black engine compartment and also inner fender wells. In the case of the fender wells, it is obvious that the black was painted over the exterior body color, as it has faded away to the original silver in many places.
    Dec 2013
    Connecticut/Florida
    Engine compartment definitely black for 1971
    1971 911S Coupe - Gemini Blue
