Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: How to prevent chemical damage to anodized surface Fuchs at tire mounting
  1. #11
    So, if the usual mounting lubricants have etching capability due to alkalinity, what about protecting the anodized surface with a generous coating of vaseline in advance?
    Then wiping it clean after the tire is mounted.
    Zed
  2. #12
    I'm good with that.
    Early S Registry #235
    rgruppe #111
  3. #13
    Pat Williams secret to black areas on Fuchs is PAM anti-stick spray. I kid you not.
    rgruppe #111
  4. #14
    That's a winner.
    PAM = Canola Oil, Palm Oil, Coconut Oil, Lecithin from Soybeans (non-stick agent), dimethyl silicone (for anti-foaming), rosemary extract (preservative), propellant.
    Fortunately, if it accidentally blows into your mouth it has zero calories.
    Zed
  5. #15
    Jul 2006
    Corvallis, OR
    Quote Originally Posted by Arne View Post
    Really? I go through a set of tires every 3-4 years. Shipping the wheels off to the wheel finisher every time you need a tire mounted seems way out of line to me. There are competent tire shops out there, you just need to find them and make sure they are on the same page as you are.
    Yeah, I was just talking about the first tire to go on after finishing like OP was talking about. Most local tire shops around me won't take on the job because they don't want to take the risk. So, I drive up to Rothsport and have them do it.
    72S, 72T now ST
  6. #16
    Nov 2003
    Santa Monica CA
    I use PS21 used to be sold at performance products. Try automotion they are back online
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
