Results 1 to 7 of 7
Thread: H+H Rear sway bar drop link bushings?
    Senior Member zenithblue71T's Avatar
    Dec 2009
    Copenhagen, Denmark
    Hi All,
    I have a 71T with H+H rear sway bar. The bushings on the drop links are perished. Any idea where I can find them or what I can use instead? I hear Weltmeister bushings plug and play. Alternatively, if I want to replace the entire rear sway bar, what do you suggest for cruiser setup that does once a year track? I do hit the twisty roads in CA fairly hard and often.
    James Hurst #1638
    R Gruppe #514
    911T with 2.2S Ps and Cs, Solex grind Cams and PMO 40mm
    Dec 2008
    Black Mountain, NC
    I would try the Weltmeister, but get their stiffer compound where they are in 2 halves sliding in from both sides and having a steel tube for alignment and wear protection for the bolt to material. They work great and simple couple of min instillation. I don't remember what they call that material but you should be able to see it. I may have a spare set in the parts bin to check a P/N. Give them a shot, minimal investment, to repair your set up.
    Dec 2009
    Copenhagen, Denmark
    Quick follow up. These were the perished rear sway bar drop link bushings Name:  509C543C-19F5-4F9F-94CE-74DBCF5DC9A6.jpg
Size:  74.6 KB and these were the other perished sway bar bushings.Name:  48874CD5-B207-425F-A488-9E6105D6024F.jpg
    I think I need to do some painting. Also, these bushing squeaked like an old bed.
    James Hurst #1638
    R Gruppe #514
    Dec 2009
    Copenhagen, Denmark
    These are the bushings that I replaced I replaced on the rear sway bar at Gavin’s Autowerks.
    James Hurst #1638
    R Gruppe #514
    Quote Originally Posted by zenithblue71T View Post
    Hi All,
    James
    Take the whole thing off and dispose of it in an environmentally friendly way. Replace your front torsion bars with 21MM bars and your rear torsion bars with 25 or 26mm bars, if you haven't already done that. Do not, I repeat, do not replace the rear sway bar. If you have a front, thru the body torsion bar, you can use up to a 18mm bar. Next year's SPD and the after drives will be much more fun following this recipe.
    Ciao
    Brown 71 911T with hollow 22 MM front bars, hollow 28MM rear bars and a 19MM under the body (stock 86 Carrera) front bar.
    Note: NO REAR BAR!!!!!!!!!!!!!!!!!!!!!!!!!
    Dec 2009
    Copenhagen, Denmark
    Thanks Jim! As far as I can tell, my 71T has the following setup:
    Front:
    I have new front Dansk/Carrera Control Arms with 22mm sway bars. I do not have the stock through the body sway bar.
    New Billstein struts
    Rear:
    Rear stock torsion bar: 23mm stock.
    Rear h&h sway bar 15mm (new bushings!)
    Billstein rear shocks
    Avon CR6ZZ on 15s all the way around
    Wouldn’t removing the rear sway bar make the car more prone to oversteer?
    James Hurst #1638
    R Gruppe #514
    Front:
    Rear:
    Actually, no. I would increase the rear bars to work better with the stiff fronts. No front sway and a rear sway is a recipe for disaster, IMHO
