Results 1 to 9 of 9
Thread: Original Hockey Puck Question
    Jul 2011
    Chicago Area
    I just bought this hockey puck here on earlyS and it doesn't have the slots for attaching the chrome trim, what do I have here? Can I just add the slots with a dremel or do I need a different chrome trim piece?
    Mike Fitton # 2071
    2018 911S Carrera White
    Mike I have the same and the chrome ring has no tabs just a pressure fit. I got it at the Pomona Swap Meet years ago and just assumed they were all the same. Not
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    mike when i saw that you bought this puck. i was wondering if you know what you are buying.
    i`d say it`s eighter a 68 only item(not sure if in 68 the puck was an option).....my68 also had this non slot version...many years ago i did reproduce the puck...unfortunatly useing a non slot as tamplate(did not know that there was a slot version)...
    or a very early one
    the inlay is press fit and glued to the puck--maybe they figured that this solution is not long lasting.and they introduced the slot/tab puck
    there is at least 3 different puck versions one version has a almost not present step
    Aug 2009
    SF Bay Area
    Mike
    I learn stuff every day, still. Feel free to send that thing back is you want.
    Jim
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    I have three of these with the almost non present step on the puck. I know one came from a 68 912 and the other two, I bought somewhere online. All have the tabbed ring too...cliff
    Would a reproduced tabbed ring for 45$ from Zuffenhausen, on eBay work with the tabs snipped off? Rather then the dremel tool fix!?
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Jul 2011
    Chicago Area
    Quote Originally Posted by Cliff View Post
    Looks like snipping the tabs might work but to be safe I am going to add the slots for them.
    Mike Fitton # 2071
    Jul 2011
    Chicago Area
    Mike
    Jim
    Thanks Jim but I think I can work with it.
    Mike Fitton # 2071
    Jan 2007
    North of the GG Bridge
    You might want to take a measurement between the friction fit ring and the tabbed ring. Or a tabbed non-tabbed puck. ASIR there is a bit of a size difference. I most certainly would not cut the tabs off of an original tabbed ring. I once had issues with the fit when trying to do the swap you are considering. It could have just been my circumstances and yours will differ.
    Oct 2011
    California
    I need to replace the leather center on a non tabbed hockey puck.
    Is there any good technique to remove the chrome ring without damaging it?
    It seems to be glued in pretty securely.
