Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Top door trim difference
    the one with the bracket is kind of 64-66/67ish(bracket discontinued during MY67 if i remember correctly)
    if the 2nd one you have is(more or less) identical to the other one (minus the bracket) its for the rest of MY67.
    (nerd info: there is at least 8 different versions for SWB---multiplied by all available vinyl colors )
    The "brackets" continued thru the 68 model year.
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    taken off from my 68L...not sure if the doors even had the slits...need to have a look... still have the doors ......somewhere
    68 911 RH side. 68s are "one year only". They look like a 69 and later part on the outside but 65 - 67 on the inside.
