Thread: Windshield Gasket Recommendation
    Hello:
    Has anyone purchased and installed a windshield gasket lately? I have heard that the Porsche sourced gaskets are having fitment issues.
    Any source that you may recommend?
    I recently (in the last 6 months) installed mine with the factory seal, and the fitment was perfect. I also used new factory moldings, so that may have helped too.
    1969 911 E #824
    Where did you hear of these fitment issues? Did one last week with a factory seal and it was perfect. No issues.
    Senior Member 9er's Avatar
    Apr 2010
    Adelaide Australia
    For a while now the genuine Porsche seals have changed in that they no longer have a slight moulded bend at each of the four "corners" and they added a flap of rubber where the seal sits on the flange.
    Credit universeman from Pelican forum for the pics.
    Cross section
    I find the seals much better to fit if I use a razor blade to remove the rubber flap all round
    FWIW I think the international mercantile version are the best at the moment.
    Jul 2006
    Corvallis, OR
    I've had more of a problem with the replacement glass than the Porsche seal. The clear repop Sigla logo glass isn't easy to install unless you have 3 people. I have my glass guy inside the car and me and another guy in each corner at the same time pushing down from the outside. With 3 people it's much easier and won't pop out in the corners. You have to center the glass and move it where needed to get the seal to look right regardless of the seal. The biggest nightmare is the quarter window seals both the inner and outer one. They're too big and insanely hard to deal with.
    72S, 72T now ST
    Thanks for the tips. What we heard was the corners were a problem. And this came from a respected vendor
