Results 1 to 2 of 2
Thread: chain tensioners
    Jun 2011
    Bellingham, WA
    chain tensioners
    Is there a way to verify a chain tensioner is bad before taking the cover off.
    I have a weird noise coming from the engine from idle to 2500rpm, after that it goes away
    It sounds more like a vibration than a metallic clang
    when I had a defective tensioner years ago, it was very pronounced metallic clang & went away around 1500rpm
    I used a stethoscope and the right side was noisier than the left
    TIA
    Tom
    72 2.4 T
    Aug 2017
    el sobrante ca.
    cant rule out broken chain ramp
