Results 1 to 10 of 10
Thread: FS: 1972 911T Coupe
    FS: 1972 911T Coupe
    I'm just completing a refresh on a non-sunroof 1972 T and have been debating whether to submit it directly to BringATrailer, or to gauge the response here, among a much more focused audience.
    Anybody have any thoughts? I'm a relative newbie to the Registry forums, and would be appreciative of any advice.
    I've attached a few photos, but have many more (and video) that can be made available upon request, as can a more detailed account of the car's history, as I know it.
    Car is numbers matching and sale includes CoA and mint condition owner's manual. Haven't settled on a BAT reserve, but would ask $85k if I sell directly.
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    S front bumper.
    Are wheels correct or date coded?
    repaint? original color?
    owner histroy?
    to get over 65k you will need to have alot of things documented.
    www.tcspeed.com
    Seattle, WA
    I think BAT is a great venue to sell your 911. At $85 they will likely try to talk you down on your reserve. You will absolutely need to have many photos of the floor of your car taken on a lift -- not sitting in the driveway. A couple good quality driving videos without music and without talking are also a must. Looks like a great car. MFI cars are exceptional!
    Thanks for the input! I've got pretty comprehensive photos, including under car and several videos. I figure I would have to negotiate a reserve with BAT, and the asking price isn't a must-have figure.
    Thanks for the response!
    The splitter is after-market, but the car was delivered with S Koni suspension, front sway bar and aluminum front calipers, all of which have been retained.
    Wheels are correct, matching set of five. I have photographs of the date stamps (among many others), but didn't want to overload this semi-exploratory listing.
    Current owner is the third. The previous owner purchased the car in 1984 kept it in and around Seattle until four years ago. It had a glass-out repaint in the original color sometime in the mid-90s. Not much in the way of documentation until the current refresh, but the coverage of that process is extensive.
    Not a concours car, but an exceptionally well-sorted driver with fairly unique equipment and no immediate needs.
    At least from what has bee presented, I don't think the reserve of $85K is unreasonable,
    From the first post, I consider it to be for sale here at $85,000.
    Peter Kane
    '72 911S Targa
    Quote Originally Posted by Hubbard's View Post
    GLWTS
    You might want to also explain:
    - the 912 speedometer
    - numbers matching? VIN, engine, trans numbers
    - body repair history with the alignment issue of passenger side front fender.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
    Early 911S Registry #548
    Nov 2015
    In all, it appears to be a decent numbers matching 1972T that you can get in and drive.
    I would assume that the paint and body along with wheels were done to a driver standard in the 1990s.
    I would get leak down numbers and compression for the motor if going on bring a trailer.
    www.tcspeed.com
    Oct 2018
    Orange County, California
    All very valid questions for proper due diligence. GLWTS.
    1957 356A Cab Condor Yellow
    1970 911E Targa “CONDA G”
    1970 911T3.2 “Meatballs”
    1972 911T2.5 “AWBRGN”
    1972 911T Targa Glaserblau
    1976 911S Talbot Yellow
