Thread: Engine/Trans reinstal.
    Member AKAMick's Avatar
    Sep 2018
    77°50′47″S 166°40′06″E
    Engine/Trans reinstall.
    What is the typical method to reinstall the engine and transaxle unit into the car, I have never done this on a 911 before, I have a 4 Ton Weaver long frame floor jack, but balancing it on a even a large frame floor jack seems a precarious proposition, the manuals show a large floor jack with a attachment cradle of some sort, what is generally used to accomplish this task?. Do I lower the car onto the raised engine unit, rather than offer it up to the car?
    Current fleet, mostly rubbish automobiles and other assorted junk.
    We did it for years on just the jack cradle of a 2 ton Walker jack. Now we use a 911 engine cradle that fits in place of the jack pad that was sourced from Pelican I think.
    Sep 2018
    Thank you Ed, just ordered this device. with my inexperience i might need to do this more than once,Name:  Removal_Jack_Adapter4.JPG
    The first time you balance engine and trans on the jack you'll set that 17 mm hex bolt for the right angle to get the trans nose angled into the tunnel hole,,,,then it will be perfect.
    I always found a helper to be beneficial!
    Peter Kane
    '72 911S Targa
    Jun 2010
    CT US
    get the tranny shifter rod in the tunnel 1st
    then raise it engine to it rear mounts.. trans mounts will line right up...
    super fast and easy
