Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Raceservice4u twin spark dissy rotor.
  1. #11
    Aug 2011
    Australia
    Thanks for the input.
    Frank is the top like this?
    Found image of H704068-01.
    S Registry#2021
  2. #12
    Banned
    Nov 2004
    Scottsdale, AZ
    Mine looks like money; lower pic in your post.
    Yours looks very cheap.
  3. #13
    Aug 2011
    Australia
    It may look cheap, but its done it's job and lasted.
    S Registry#2021
  4. #14
    Banned
    Nov 2004
    Scottsdale, AZ
    So why do you need a new one?
  5. #15
    Aug 2011
    Australia
    Time to replace.
    S Registry#2021
  6. #16
    Banned
    Nov 2004
    Scottsdale, AZ
    Classic.
    I would think the going price for really nice Marelli rotors would be at least $750? Perhaps peanut gallery has input.
  7. #17
    mar, is there a carbon brush for the second rotor. I’m with Frank, it looks inexpensive, almost home made.
  8. #18
    Jan 2011
    Sunny Southern France
    Hi.
    DO you have an original Marelli dizzy or a repop? All repops arn't made equal. Some use the same rotor and cap and some others use a Jagar V12 rotor/cap assembly.
    If you have an original, you'll probably find what you're looking for here:
    http://maseratisource.com/maserati-3...gnition-rotor/
    Olivier.
  9. #19
    Aug 2011
    Australia
    Thanks Olivier.
    Mine is repop, running with the Jag cap and custom rotor arm.
    Another member has exact rotor arm available pictued in my original post, that I will most likely take him up on. Meanwhile the engine is now out of action and due to be pulled down at a later date for further inspection after finding two metal flakes on the sump plate and fine metalic specs in the oil filter element.
    S Registry#2021
