Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: Muffler experience
  1. #41
    Sep 2018
    Netherlands
    To my inexperienced eyes the Porsche classic muffler looks authentic enough, wat am I missing? (Do I really want to know -- once you see it it can't be unseen...)
    1970 2.2S Elfenbeinweiss
    2002 996 TT Midnight Blue
    Member #3833
  2. #42
    Oct 2010
    Southern Ca.
    Hello frederik , to my experienced eyes the Porsche Classic muffler looks very authentic , you are not missing anything . And good to read you are happy with the sound , I also think there is no comparison to the Dansk .
  3. #43
    I am referring to the mufflers used on early? Swb cars. Those are quite distinctly different in construction compared to the Porsche classic muffler
  4. #44
    See attached pictures. As you can see the early mufflers had an additional "shield" around them similar to whats sees on 356 mufflers. The Porsche classic muffler does not have this. There are also other small differences.
  5. #45
    Jun 2012
    London, Ontario, Canada
    Quote Originally Posted by Richy View Post
    The Porsche Classic muffler is definitely the most quiet , and sounds good , much like an original Leistritz . I have one on my car .
    Ditto. Sounds good and "adult like". You can converse in the car.
    Early 911S Registry # 2395
  6. #46
    Aug 2011
    Eugene, OR
    Quote Originally Posted by Arne View Post
    Update - After looking into the sub-optimal tailpipe/bumper fit of the really nice sounding Bischoff on my car, I found that mine appears to be original for a '74 G-body.
    Since it sounds good, and appears to be in fine shape otherwise, I plan to have the taipipe cut off and re-welded at a more bumper-friendly angle. Can't see getting rid of it when its only shortcoming is easily fixed.
    Turns out I was wrong. While my Bischoff is not original to my car (dated 10/73), it does appear to be correct for my car, showing part 911.025.00.
    The poor tailpipe fit appears to have been from poor collision repair of the left bumper.
    - Arne
  7. #47
    Dec 2009
    Copenhagen, Denmark
    I think the first time I wrote something about it was on 12/2000... When I was still a guest on the board...
    http://www.early911sregistry.org/for...ffler-opinions
    Hope any of this old thread helps...
    Chuck
    Epic thread Chuck. Thanks for the post.
    James Hurst #1638
    R Gruppe #514
  8. #48
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    Quote Originally Posted by EisenmannNA View Post
    No problem at all. Happy to have found this forum thanks to George.
    P91127.00600 = carbon steel "non stainless" but the photos on the iND site are made using the CAD design so they appear to look like an SS system. Eisenmann Germany wanted to make sure that the system not only looked 100% factory but the sound had to be exact.
    hi Eisenmann, do you happen to have comparisons (build, drawings internals, etc.) and / or comparison measurements (sound / HP performance) with the early Bischoff / Leistritz (or any other) mufflers? thnx.
    911S 1973
    Early 911S Registry #176
  9. #49
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Tom,
    better reach him over his homepage
    https://eisenmann-exhaust-systems.de
  10. #50
    Jan 2003
    The Netherlands
    Quote Originally Posted by dirk07 View Post
    Tom,
    yep, thnx Dirk. But thought it would be interesting to fellow members, if they could show some more info here. (will ask there as well) T.
    911S 1973
