Thread: Faulty ignition switch? Maybe
    Friends, I have run into a problem with my ignition witch. It cranks occasionally, but will turn the car off at the slightest shake of the switch. Below are two pictures of my switch.
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    If it is a bad switch what would be the correct replacement as all I can find are bullet connection switches. This is for a 1968 911
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    Aug 2009
    SF Bay Area
    You can replace it with a generic Bosch Ign Switch. Haven't checked lately but youy should be able to buy one for around $60.00 or $70.00. You can use the same bezel. I make up a harness to go from the switch (which has screw on terminals) to your spade terminal wires,. Very easy and nothing need to be altered or any wires cut. There are people that rebuild these switches but it usually takes a bit of time, thus the need for an interim replacement.
    Jim
    PS: Whats up with all the chopped off wires?
    Did what Jim recommended above, car starts and is reliable, any one out there know where I can get my original ignition rebuilt?
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
