Results 1 to 8 of 8
Thread: Muffler Identification
    So what do I have here? I was only able to find this mark on this part. Where would the Leistritz Marking located at? Is Leistritz Original equipment to the '65 & early '66 911?
    Uneducated on Muffler Originality, looking for Knowledge. Thank You for your input. (this came off of my 1965 built 1966).
    Yes, I did not see anything to the left. Any farther over starts to get into some heavy corrosion. It is possible that it could be aftermarket with the 901/01 stamped on it?
    I will clean it some more.... thanks.
    I Will dig the original muffler of my december '65 coupe out tomorrow and take some pictures
    Thank You, that would be very helpful.
    Only stamped marking found on my muffler, it's located in the center.
    Ernie W
    member of Early 911S Registry
    See attached picture, says Leistritz 901/1 in the location indicated in your picture
    Here is a photo from my May ‘65 911. It’s in the same location. Even though the OP photo doesn’t have the manufacturer, the number font looks the same.
    I FOUND IT!!! Its original. Thank You.
