Results 1 to 10 of 13
Thread: Seat rail supports for tombstones in longhood
    I'm searching for impact bumper seat rail supports (1st series) but I'm having trouble looking for part numbers as the ones listed in PET catalogue are 2nd series unfortunately.
    Here is a pic (No affiliation). These are the type of supports I want. Any ideas where I could get them?
    Apr 2003
    Portland, OR
    Make your own from steel plates.
    Harry
    Member #789
    2009 MB C300
    Thanks for the drawing. Much appreciated.
    Not sure if I understand fully but are the inners (tunnel) the same as the outers? (mirrored image)
    In the photo above, the factory seat rail supports seem to be tilted back at a slight angle. Are yours flat?
    Do you have a photo of your supports in a car if you don't mind me asking?
    Apr 2003
    Portland, OR
    Quote Originally Posted by blue72s View Post
    The plates are mirrored flat steel. I bolted mine on top of the existing rails for the original seats.
    Harry
    Member #789
    2009 MB C300
    Hi I took these off my 1971 911. They were adaptors for tombstone seats.They were attached to the seat rails from what I remember. Returned car to stock seats.
    $20.00 plus shipping if you would like them.
    johnnyt356@telus.net
    Thanks John
    Quote Originally Posted by HarryD View Post
    It seems to me that your drawings are for outers only, as the inners have different bolt locations. Here is a photo:
    Quote Originally Posted by alberta View Post
    Thanks John
    Thanks for the offer but not what I'm looking for.
    Regards.
    Apr 2003
    Portland, OR
    There is a factory piece that bolts to those locations and then the adapter plates bolt to those.
    Harry
    Member #789
    2009 MB C300
    OK I think I get the picture now. Thanks.
    However, the factory version ('74 -) brackets are tilted back a bit. Do you find your seating position on flat plates comfortable?
    Apr 2003
    Portland, OR
    I have not noticed as issue.
    You will notice that in my third picture, I had some "ears" welded onto the plates with a 7/16-20 nut to give me a seat belt attachment point. These are on both sides of the seat.
    Harry
    Member #789
    2009 MB C300
