Results 1 to 9 of 9
Thread: Blinking light on new to me 75 Carrera
    Sep 2009
    Roseburg, OR
    Just a question, I recently purchased a 75 Carrera.
    At the top of the oil pressure gauge is a blinking red light that only goes out when the key is turned
    off.
    Its not described in the owners manual.
    Thanks, John
    Aug 2009
    SF Bay Area
    That is the E brake warning light. Fiddle with the E brake lever, you are not getting it all the way to the floor.
    Jim
    Apr 2003
    Portland, OR
    when this happened on my 1973.5 it turned out to be a failed brake cylinder switch. I was able to diagnose it by unplugging the connector from the brake cylinder.
    Not sure if it is the same in 1975 but the Brake cylinder switch and hand brake switch share a common circuit.
    Harry
    Member #789
    2009 MB C300
    Sep 2009
    Roseburg, OR
    Thanks.
    Its not the hand brake lever, I did try that.
    Will try the switch.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by john wurner View Post
    Thanks.
    Have you checked and adjusted the switch on the E brake lever?
    Ciao
    Jim
    Sep 2009
    Roseburg, OR
    Red light blinking
    Ciao
    Jim
    Thanks, my next try.
    Apr 2003
    Portland, OR
    Pull the wire connector on the master cylinder to see if the blinking light stops. If so, it is a bad switch.
    Harry
    Member #789
    2009 MB C300
    Sep 2009
    Roseburg, OR
    Quote Originally Posted by HarryD View Post
    OK, thanks.
    Bad switch.
    Apr 2003
    Portland, OR
    OK, thanks.
    Bad switch.
    Glad you found the problem. The switch is not expensive and easy to change.
    Harry
    Member #789
    2009 MB C300
