Results 1 to 10 of 14
Thread: Steering rack bearing question
    Aug 2010
    This bearing seems to have a very light detent or ratcheting feeling.
    Is this correct or should it be smooth. If smooth is there still a source.
    There should be a brand and number etched on it.
    I don't think any bearing should feel ratchety, doesn't look like it has much grease packed in.
    Aug 2010
    Germany FAG 6202.
    Do I go to a bearing shop, Porsche or one of our vendors?
    It also has a T. Then something I can’t make out. A, R, 8?
    Aug 2010
    Can this be sanded with fine wet and dry sandpaper on a honing surface?
    Sweden
    Quote Originally Posted by Chris Pomares View Post
    Germany FAG 6202.
    You probably find the bearing in any machineshop supply or maintenance supply shop or a shop that rebuild electric motors, it's a very common size in europe. You can find them in almost every drillpress etc.
    I just turned mine 90 degree, but it was not as worn as yours
    Light Yellow -74
    @lagteknik
    Aug 2010
    I just sent JimmyT a message to see if he'll make some pucks/pistons. Anyone else interested?
    I think that you may need 901.347.929.00 Steering Rack Repair Puck, -'68, $5.99 from Stoddard.
    Like many things, they changed the design in mid '68.
