Thread: What temp is this???
    Senior Member 767driver's Avatar
    Parkton, MD
    Hi Guys,
    The picture is from my 914-6 before I had my aux oil cooler installed. I am curious as to what temperature this reading actually represents. I am also curious to what the actual oil temp would be when in that hashed orange zone prior to the solid orange zone. Any ideas???
    Name:  oil temp high.jpg
    Lee Fishpaw
    O Gruppe #20
    Early S Reg #2175
    R Gruppe #714
    '70 914-6
    '88 911
    '85 928S
    '74 260Z
    '74 TR6
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Head to Harbor Freight and buy a digital laser thermometer gun for about $40. Go for a brisk drive then take some readings of the oil lines, cooler etc. at various temperature-gauge readings...this will tell you the approximate oil temp at various positions of the temperature-gauge needle.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Parkton, MD
    This happened 12 months ago...car now has aux oil cooler. Trying to determine how hot it got then. Now it runs cool and has a gauge with actual numbers on it.
    Lee Fishpaw
    O Gruppe #20
    Early S Reg #2175
    R Gruppe #714
    '70 914-6
    '88 911
    '85 928S
    '74 260Z
    '74 TR6
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    start of redline is 156 C, http://www.p914.com/p914_gauges_combo.htm
    registry #2072
    May 2006
    CT
    156 deg C (313 deg F) seems really high. I read the gauge link for the 914/6 to say:
    "This temperature scale is multicolored and equipped with a warning light (amber section as in the fuel gauge insert. The scale is from 50-66 degrees Celsius in the white-striped warm-up zone, the single white line 66-129 degrees Celsius operating range with a 109.5 degree optimal marker (straight up), 129-144 degree red-striped danger range, followed by the solid red "higher than 144 degrees Celsius - your engine is cooked" range."
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Parkton, MD
    Quote Originally Posted by tom1394racing View Post
    156 deg C (313 deg F) seems really high. I red the gauge link for the 914/6 to say:
    Thanks guys...that seems to be the answer.
    Lee Fishpaw
    O Gruppe #20
    Early S Reg #2175
    R Gruppe #714
    '70 914-6
    '88 911
    '85 928S
    '74 260Z
    '74 TR6
