Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Euro rear fog light (police needed)
    I'm looking for a Hella rear fog light but apparently there were two different models - K8403 and K8415.
    Pictures below show that the K8403 has plastic lens that is flush fit with the chrome housing whereas the K8415 has a slightly bigger lens.
    Is the bulb design also different? (I seem to remember when I had my previous car '72 911 I was not able to find a replacement bulb for the rear fog light).
    So, which is more correct for model year 1970 911?
    Thanks in advance.
    K8403
    Name:  Fog side K8413.jpg
    K8415
    Name:  Fog side K8415.jpg
    Dec 2010
    Southold, NY
    Installed a Hella 003030151 to serve as a third brake light in the space left vacant by use of an aftermarket exhaust system. Lamp is a red LED 1156-R27-T from superbrightled.com. Works perfectly and is quite bright.
    Senior Member joegt3cup's Avatar
    Mar 2004
    Colebrook CT
    My understanding K8403 is used on SWB cars.
    Joe Annicelli
    Early 911S Registry #751
    Polo Red/Black 1967 Porsche 911S Coupe "Walter"
    Black/Red 1967 Alfa GTJr. Coupe "Nero"
    Italian Red 1994 Ducati 900SS/SP looks fast standing still
    Italian Red 1957 Gilera 150 Sport
    Ahhhh the sixties... I envision myself one early Saturday morning wearing plaid shorts, black shoes with white socks smoking a cigarette heading to the hardware store to buy a bag of nails.
    SWB cars are an acquired taste however once acquired theirs no turning back.
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Try: 911_2.2T he is near to you & usually has the goods! He will know what is correct for a 72. cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Quote Originally Posted by ejboyd5 View Post
    Sorry if I wasn't clear in the first post, I'm from the UK and would like to have a rear fog light, not a third brake light. Thanks anyway.
    Quote Originally Posted by joegt3cup View Post
    Yes, that makes sense. I believe this uses a bulb type that is no longer available anywhere (obsolete).
    Quote Originally Posted by Cliff View Post
    Thanks for the info
    It's for a 70 actually. I don't have the 72 anymore. Maybe I should change my username.
    Dec 2010
    Southold, NY
    I clearly understand that you are looking for a rear fog light and was merely showing you how a Hella 003030151 (larger lens) can be repurposed from being a rear fog light to being a third brake light and supplying you with a reference to a bulb that works well with the Hella housing.
    OK thanks
    I've just found out that there was another type that looks the same - K8442
    Does anyone here have an old Hella catalogue for references?
    Thanks.
