Results 1 to 2 of 2
Thread: Steering wheel binding against the clamshell on my 67
    So, when I tighten down the nut all the way, my steering wheel is binding against the clamshell on my 67 car. I found the following thread discussing a similar problem and Jim B. mentioning a "steering shaft adjustment". Compared to Jim's photo, my steering shaft does seem to be slightly more recessed than the one in the photo. Any tips on how to adjust this? I don't need much. Probably a couple millimeters.
    Figured it out. I was missing the steering shaft bearing support ring. All good now.
