Thread: 1973 911 mfi cold start nozzle? please help
    I am looking to replace the plastic cold start nozzles on the bottom of the stacks for my mfi. They are plastic elbows or t's. I want to replace the fuel line leading to them but am concerned that the plastic fittings will brake when I try. Any idea on replacements? I found one company that sells brass but are outrageous. Looking for there options.
    Oct 2010
    Southern Ca.
    They are NLA . Be careful .
    Jun 2012
    London, Ontario, Canada
    Two hundred bucks is a lot cheaper than an engine fire. https://sierramadrecollection.com/Co...73-p30589.html
    The plastic hardens with heat and age and will eventually fail, especially if you try pull the hoses off. If it were me, I'd replace with brass.
    BTW, the plastic ones were more expensive even when they were available. Almost $200 just for one elbow. https://www.rosepassion.com/en/cat/p...d-pipe/P280131
    Ravi
    Early 911S Registry # 2395
