Thread: 1971 911S Fuel Tank. Lines Sizes?... Photos would be Great. ;o)
    I have a bit of a dilemma. I have a '71 911S that I'm attempting to connect the brand new gas lines. to the gas tank fittings.
    This car is being restored. SO... I have a brand new banjo fitting... 14mm style. Correct for a '71 911S. 1971 is the first year
    that gets the 14mm banjo fitting. The gas hose the goes onto it is a 8mm id hose. That is the "large" hose..... THEN... there
    is a smaller hose for return. Correct? But... the fitting that goes into my tank will only fit a 8mm ID hose. ANOTHER large hose.
    Seems like the return line fitting should be for the smaller hose.
    Hopefully this all makes sense.
    You have things reversed in the picture . The fitting marked gas return is the supply . For an MFI car the fitting is 10 mm , and the supply hose is 9 mm ID . The fittings are available in 8 mm and 10 mm sizes . The banjo fitting is for the return line and is 8 mm , and the return line is 7 mm or 7.5 mm . Simple really .
    Dec 2013
    Connecticut/Florida
    I've been somewhat confused on this issue also.
    1971 911S Coupe - Gemini Blue
    The small sock is for the webasto
    Dec 2013
    Connecticut/Florida
    Interesting. My car has no Webasto. And a regular fuel line was connected. Ed, are you also saying that what is described by Richy is correct?
    1 Sock
    1 Banjo in center hole
    1 plug
    Yes, engine feed banjo is larger one on left side of tank, return is center, no webasto, no line to that fitting.
    Awesome! Thanks so much! ;o)
    I hope you aren't really using that hose clamp in your picture.
