Results 1 to 10 of 11
Thread: 1972 only shifter question
    Hi,
    I was wondering if someone could please tell me if the 1972 shifter below is for a 4-speed or a 5-speed 915 transmission?
    Thanks very much!
    Name:  915 shifter bottom 1972.jpg
    Name:  915 shifter top 1972.jpg
    Member #3127
    Aug 2009
    SF Bay Area
    It is for a 5spd but has a silly short shift conversion.
    Jim
    Thank you so much Jim, does that mean it cannot be put back to stock or should I just look for another one?
    Frank
    Member #3127
    Aug 2009
    SF Bay Area
    You just need to replace the lever. You can use one from any 901 shifter preferably from 68 o
    Thank you so much Jim, you have been a great help to me!
    Frank
    Member #3127
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Jim
    and it is a -71 shifter
    Jun 2011
    Bellingham, WA
    dirk07, no 72 shifters were like that as well, 73 is when the change occured
    A 72 was a one year only shifter, there were an additional couple small springs and a lock out lever.
    Does anyone have a picture of a 72 only shifter?
    Apr 2016
    Stuttgart, Germany
    upper: -71
    lower: 72
    details:
