Thread: Free brake line connections...
    Oct 2018
    North Scottsdale
    Have new calipers from Eric (PMB) and am replacing the flexible lines while I'm at it. Even with flared end wrenchs having a hell of a time loosening the connections at the hard lines. Afraid I'm going to strip them even with the flared wrench. Sprayed a bunch of lubricant and will try again tomorrow.
    Any suggestions??? Heat? Name:  IMG_9251.jpg
    1971 914- original owner
    1973 914 2.0
    1972 911T targa
    2016 981 spyder
    2014 turbo S coupe
    2019 RS5 sportback
    Yes, try heat, get the fitting hot, then spray with your favorite penetrant,,,,it will smoke so be prepared. Even at that I occasionally have had to go cave man and use vice grips. Of course you will then need to replace the line. I always assemble them with antiseize.
    Dec 2010
    Southold, NY
    Sometimes necessary to cut the line and place a socket over the fitting .
