Results 1 to 10 of 16
Thread: MSD delete - distributor wiring assistance
    Member dogLeg's Avatar
    Aug 2015
    SF Bay Area
    Working on an MSD delete on a 70T and adding a Partsklassik CDI & Coil, fortunately the PO left almost all of the original wiring.
    I am in the homestretch however am wondering where/how to attach the purple/black & black to the ignition dist. and thinking this one may just be missing the clip at the base to attach purple/black & black to? The black/red is newer wiring.
    How does the Purple/black & black attach to the ignition?
    Any & all assistance appreciated!
    Another angle of what's there..
    Tim
    1970 911T
    #3257
    Nov 2004
    New Zealand
    Tim
    I found this diagram really helpful, and should cover what you need to know.
    The purple black goes to the male spade on your distributor (marked "points")
    Mr John Cramer's I believe?(apologies to the original author/poster if incorrectly attributed)
    Good luck
    NathanName:  Early+Car+CDI+diagram1136439273.jpg
    Aug 2015
    SF Bay Area
    Very helpful, thanks Nathan. Does anyone have a pic of the male spade location so I can see where to add one? Mine is missing. Thanks.
    Tim
    1970 911T
    #3257
    The red and black wire coming from the distributor, is where the original connector for purple wire would connect. The red and black wires look like a Pertronix (points replacement). Show us the inside of the distributor, and for grins the MSD box.
    Aug 2015
    SF Bay Area
    Inside of the Bosch below, looking like a rebuilt dist. is in my future.
    Tim
    1970 911T
    #3257
    Are you trying to replace the Pertronix?
    Aug 2015
    SF Bay Area
    The goal was to swap it back to an original look with a Partsklassik CDI & coil and delete the MSD. I didn't know there would be an issue with distributor connection (missing spade) to the original wiring. I am open to replacing the dist. with a rebuilt, replacing the pertronix, or if I could connect the black purple to the pertronix that would work too. I would like to have the original wiring back in place.
    Tim
    1970 911T
    #3257
    You use Male spade connectors, a double to connect power to red pertronix, and a 'Y' connector to join black pertronix wire with black point wire and blk/pur. tach. wire.
    Member AKAMick's Avatar
    Sep 2018
    77°50′47″S 166°40′06″E
    Doesn't a 70T usually have a Marrelli distributor?
    Current fleet, mostly rubbish automobiles and other assorted junk.
