Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: MSD delete - distributor wiring assistance
  1. #11
    Oct 2010
    Southern Ca.
    That is a picture of a Marrelli distributor !
  2. #12
    Member dogLeg's Avatar
    Aug 2015
    SF Bay Area
    Thanks Ed.
    Tim
    1970 911T
    #3257
  3. #13
    Looks like am iron Bosch distributor and rotor is definitely Bosch.
  4. #14
    Aug 2015
    SF Bay Area
    The red power from the distributor was connected to the red below with an add on wire (it was unplugged unlike the pic below, I plugged it back in as seen to power the CDI).
    Which red should I connect the red distributor wire to? There is no red on the original diagram to the distributor.
    this is the red that needs power..
    Thanks!
  5. #15
    On the original wiring there was a red wire just below the relay board with a rubber covered Male spade. That connected to a rubber covered female spade that went to the middle terminal of the CD plug. That circuit is switched 12v (ie ignition on) that is what needs to connect to red pertronix wire. I have no idea what previous mechanics have done to that wiring.
  6. #16
    Aug 2015
    SF Bay Area
    Found it, connected all as instructed and she fired right up!
    Thanks Ed!
    Tim
    1970 911T
    #3257
